[robi1000] Clio Williams, AX GT/Sport, BX 16S, 405 T16...
- cliosteph
Re: [robi1000] Clio Williams, AX GT/Sport, BX 16S, 405 T16..
moi j comprend pa se qui se dit,no speak englisch!
mai le garage et joli,me plairez sa
These are mine (shot with my Ixus 120IS compact)
15 years of Renault Sport exhaust manifold evolution in one pic
94' Renault Clio Williams, nr. 6035
90' Citroen AX GT/ Sport
88' Citroen BX MI16 GTI 16S
No problems, you can reply in French, I'm using google translate, because I can't understand French either (ok I understand a little bit, but still useless)!cliosteph a écrit :moi j comprend pa se qui se dit,no speak englisch!
It was a busy day at work today, so I needed something to relax me a little bit...
For quite some time now I was playing with the idea that I could use Minicraft model drill with some brush tips to clean aluminium, but never had the time to actually try it.
Here are results of 10 minute work on a Brembo caliper. I might try to add some polishing paste tomorrow!
Guess which side was cleaned
And I got this result with used brushes, would be even better if I had new ones!
It's been a while since my last update, but my Willy has taken a backseat in my life at the moment. I'm still working on my inlet manifold and I'm almost done now.
Here are some pics of the work when I started and somewhere in the middle. I'll post pics of the end result later.
Weld protruding into the runner
Some misaligment
Looks awful, but the final result will be ok
Some misaligment
I went to my garage today and spent one full hour there, which is more than all the time combined in the last 3 months.
Anyway, I trial fitted some 300mm front discs and 4 pot Brembos! I think it looks good!
Comprend rien mais c'est beau ...
Beau montage jantes gr A et étrier BREMBO
Ne t'en fait pas "16s white" tu peux commenter en français car robi1000 traduit avec Google traduction.
C'est exact!Alesc 60 a écrit :robi1000 traduit avec Google traduction.
