[robi1000] Clio Williams, AX GT/Sport, BX 16S, 405 T16...
robi1000
Re: [robi1000] Clio Williams, AX GT/Sport, BX 16S, 405 T16...
Message par robi1000 » 14 nov. 2011, 21:24
Car was resprayed in early 2011
(this is a copy/paste from my thread on Williamsclio.co.uk)
It's so beautiful that my camera is just not good enough to capture the real shade and depth of colour. Few pics for now, others will follow a bit later because I would like this thread to be chronologically correct as much as possible. So, here are some from the bodyshop...
Washing and degreasing
After new arch was fitted (sadly no pics of this being done)
Rust removal from the right arch (there was one small 3mm rust bubble)
I like this one... Door and bonnet in primer
Mmmmm...
This is one of my favourite pics!! :D
And just a few teasers...
To be continued... :P
94' Renault Clio Williams, nr. 6035
90' Citroen AX GT/ Sport
88' Citroen BX MI16 GTI 16S
robi1000
Message par robi1000 » 14 nov. 2011, 21:25
Resprayed:
Funny mirror
Freshly painted engine bay (still dusty)
I like this one, shape of the car really shines here
We have no engines do we?!? (FF quote) I hope to change this soon.
What can I say... I'm in love with this bonnet bulge! :D
Image[/quote]
robi1000
Message par robi1000 » 14 nov. 2011, 21:26
Goodies! :D
INSPECTION! :lol:
Trumpet band - best music in the world
And their music conductor
Also bought new tyres
Federal Motorsport 595 RS-R
Can't wait to try them out!
robi1000
Message par robi1000 » 14 nov. 2011, 21:29
I did some work on ITBs. I removed secondary butterflies and provisionally seperated the throttle bodies to see how should I space them. Here's a pic of them reassembled, but without secondary butterflies.
Wuuuuuuu, a small but very heavy pallet arrived today! :D
After I unwrapped it I found... F7R 714 with modified head and some other goodies 8)
Inside that Pagid box is a 172 flywheel (60-2 pattern for my standalone) with 172 clutch.
Short rad for my ITB conversion
Good cooling is a must
Some sort of art :lol:
My inspiration :)
Injector seals. Good to have some spares.
172 flywheel with 60-2 tooth pattern
172 215mm Valeo Clutch
Trial fitment of two fans for better cooling (will probably buy something from Pacet fans)
)Image
Message par Miaouw67 » 14 nov. 2011, 21:30
really nice update on your williams :)
What will you do to optimise the OEM brakes.
more power => more brake needed :)
robi1000
Message par robi1000 » 14 nov. 2011, 21:34
We will come to brakes in a moment, I just have to re-post/re-paste all the work from the last 2 years... :D
Anyway, we continue:
F7R 714 is a different engine. It's practically a F4R bottom end. So it's held together with different kind of bolts (external torx). New tool box was needed. :)
And then I finally started dismantling 714 engine:
Cambelt and plastic covers removed
Sump and chain oil pump removed. Pistons and rods are also out. Notice different bolts.
Just for comparison... This is F7R 710 (on the same table :P)
714 crank removed:
I just have to take apart my old engine to get my old forged Wossner pistons out. After that I'll send the block away for rebore.
Raw aluminium, soon to become my custom inlet manifold :)
Some of the presents I got for my birthday from my mates. 4th mount and some tools. :D
ITBs wrapped in a protective foil. Can't stop looking at them. :D
Image[/quote]
robi1000
Message par robi1000 » 14 nov. 2011, 21:36
Finally got round to dismantling the "old" engine.
Head off
Forged pistons inside...
... and then they magically disappeared! 8)
Then I decided to remove the steering rack, beucase it needed some TLC
Removed rack
Before
Fresh lick of paint
Brackets also
Oh and my friend bought a car lift, so work should be easier once we fit and wire it
And we started to cover the floor with poliurethane to keep the dust to the absolute minimum.
robi1000
Message par robi1000 » 14 nov. 2011, 21:38
Ok, my old engine is almost fitted back in the car. I will fit it so that I can make my new inlet manifold and work on my new engine at the same time.
This is my old steering rack rubber
F7R 714 on it's way to be rebored
Old engine fitted back in the bay
Working with forklift makes everything so much easier
KONIs fitted
Short rad trial fit
This is how inlet runners should be angled
Short rad is definitely a must for a decent ITB conversion
robi1000
Message par robi1000 » 14 nov. 2011, 21:40
I started my battery relocation project:
I'm trying to find some sort of optimal layout. PAS pump is the problematic area, along with alternator bracket (but that can be fabricated). I really don't want to ditch PAS, because I will run 16'' rims (and I was just minutes ago driving non-PAS Clio and I really hated the steering feel). Shorter rack is really noticable on valver/Williams.
Well, hopefully I will be able to retain original PAS setup. I plan to go electric later, but that will be for increasing power.
Obviously Saxo VTR pump is a good fit. I also looked at Mercedes A class and Honda S2000.
But I would prefer original Renault electric PAS pump, that was fitted to LHD cars with AC.
Anyone has one for sale?
robi1000
Message par robi1000 » 14 nov. 2011, 21:43
Block came back from the machine shop. It was rebored to 83.50mm.
Waiting to be assembled
New Wossner piston rings. They cost a fortune! :(
Block degreasing
Wossner forged rods
Mated to a Wossner forged piston
I've done a lot of measuring and weighing lately, to ensure every part will be assembled correctly.
This is again a repost from another forum dated around August 2011:
I'm working really hard to finish the car till 1st September when car will be exhibited on Renault stand on our biggest car show.
I waxoiled the sills and rear quarter panels, hopefully protecting them from rust spreading quickly
Before
After
Lots of waxoil
Bitumen as sound proofing (and some rust protection)
Cleaned and prepared door cards and interior plastics
Roughly the state car was in a few days ago, and less then one month to car show :?
Battery relocation project :)
Rims are really finished cleaning wise, and are now at a machine shop which will cut the lip. After that comes a fresh lick of R9312... ;)
