**Will 98' 1.9D (F8Q) Kangoo crankshaft fit in my Williams (F7R 710 - Megane)? I know Clio and R19 1.9D fits. I hope Google translate didn't cock up too much!
Kangoo vilo
Kangoo vilo
Accès va vilebrequin 98' 1.9D Kangoo dans ma Williams (F7R 710 - Megane)? Je sais Clio et R19 F8Q 1.9D est bonne.
94' Renault Clio Williams, nr. 6035
90' Citroen AX GT/ Sport
88' Citroen BX MI16 GTI 16S
- Franckymania
Re: Kangoo vilo
Seems the same ref for Kangoo F8Q 632 and Williams F7R A700. Seems different from F7R 710.
Re: Kangoo vilo
je parle pas anglais
mais les vilos de williams et mégane sont les memes donc tu peux monté un f8q de diesel
Re: Kangoo vilo
Merci!
Re: Kangoo vilo
Would Clio RS crank fit F7R 710?
- Pedro Lito
Re: Kangoo vilo
Pozdravljeni !robi1000 a écrit :Would Clio RS crank fit F7R 710?
No.
The length of the piston path is entirely different.
I know perfectly your country and the potica !!!
Havin' fun in Slovenia.
Re: Kangoo vilo
Ha ha ha! I must say that when I first read what you wrote I thought that some virus is doing some magic and translating words on forum. I would never expect to find someone who could write Slovene!
I hope you enjoy potica and that you have tried "gibanica"! If not, it's a must!
Also thank you for your technical input. Not exactly sure what you meant by "length of piston path" (stroke is the same)? Crank journals don't align with piston bores?
- Pedro Lito
Re: Kangoo vilo
length of piston path = the distance traveled by the pistonrobi1000 a écrit :Ha ha ha! I must say that when I first read what you wrote I thought that some virus is doing some magic and translating words on forum. I would never expect to find someone who could write Slovene!![]()
You know what I mean ?
Re: Kangoo vilo
I suppose you mean "stroke ("course" in french?)". Both are 93mm. Why wouldn it fit? Or did you mean something else?
- Pedro Lito
Re: Kangoo vilo
It's seems that's true.robi1000 a écrit :I suppose you mean "stroke ("course" in french?)". Both are 93mm. Why wouldn it fit? Or did you mean something else?
